I don't know either, with a quick search I found the below details.
http://datsun1200.com/modules/mediawiki/index.php?title=BCDD
Boost Controlled Deceleration Device (B.C.D.D) serves to reduce HC emission emitted from the engine during coasting. It is used by some Datsuns
The high manifold vacuum during coasting prevents the mixture from complete combustion because of the reduced amount of mixture per cylinder per rotation of engine, with a result that large amount of HC emission is emitted into the atmosphere.
B.C.D.D. has been designed based on the idea of eliminating this objection. It operates in such a way that, when manifold vacuum exceeds a predetermined value, it provides and additional mixture of optimum mixture ratio and quantity iinto the manifold by opening the separate mixture passage in the carburetor. Complete combustion of fuel is assisted by this additional mixture, and remarkably reduces the amount of HC contained in exhaust gases.
During the period from coasting to idling, the transmission produces a signal which in turn energizes the vacuum control solenoid. As this takes place, the valve is lifted off its seat, releasing the vacuum chamber to the atmosphere. The mixture control valve will then be close, returning engine speed to the predetermined idling.
It's bolted to the underside of the injection manifolds, i have a couple here in Brisb, but am away till 7th Nov, f you can wait.
I'm glad to hear that.
I can waiting anytime. plz sent to email
Thank u
  • 2 weeks later...
              G'day Chang. are you still after this part mate as I have a cple of spares .
                                  Regards: Alan.
Hi Chang.
I have one along with the whole manifold. You messaged me on ebay, i replied with pictures as requested but you never got back to me..
                                  Regards: Alan.
Hi Alan. but i'm found it
I'm so sorry and thank you
