aegean Posted November 15, 2007 Posted November 15, 2007 Is there any interest in reproduction chassis plates ? I reproduce these for the old Mercedes and since my 260z plate is not too great, I am looking to replace it. I have found a company in the US that sells replacements, but only for their model - as per the photo below. To have one reproduced with GRS on it, they want an order for 100 units, and I don't think we would be able to sell that quanitity here. I can have them done individually, with the chassis number stamped (or printed) but will have to get them set-up initially - all of which means that they will cost more than the ones from the US. I estimate that it would be around $52 each, postage included. These are some of the plates I am having produced in Germany. The chassis numbers are printed in these examples, but can be metal stamped. Don't worry about the distortion - it's just the angle of the photo ! Quote
Mr Camouflage Posted November 15, 2007 Posted November 15, 2007 One of the guys over here had his plate redone. I don't remember the exact details, but I believe he took it to a printer who reproduced the black parts as some sort of sticker. I think he then cleaned off the plate to remove the original black, and stuck the sticker over the top. I'll ask next time I catch up with him. Quote
mtopxsecret6 Posted November 17, 2008 Posted November 17, 2008 i know this is an old thread.. but did we work out where to get our plates re done? as mine is virtually un readable. Quote
aegean Posted November 17, 2008 Author Posted November 17, 2008 I will be having mine redone properly by the people that make the Mercedes (and other) plates for me in Germany. There are quite a few varations as I have discovered though - some minor, some not. For example, on the US plate I pictured below, there is a line between the Car Number field and the box beside it. On my original (1974 2+2) plate, there is no line, as you can see on the following photo. Quote
mtopxsecret6 Posted November 17, 2008 Posted November 17, 2008 thats what mine is spose to look like.. but you cant read anything at all. so how much is it to get it redone? Quote
aegean Posted November 17, 2008 Author Posted November 17, 2008 It is still going to be around the original price I posted a year ago - even though the AUD has declined quite a lot since then. Quote
V8Datto Posted November 17, 2008 Posted November 17, 2008 Can you get all the different z plates made? or just a few? I'd be interested in a remake of an early 240z plate Quote
aegean Posted November 17, 2008 Author Posted November 17, 2008 As long as I have a photo to work from, and the size, it is no problem to make other plates. Quote
scrumpy Posted November 19, 2008 Posted November 19, 2008 Aegean. I have a 260Z coupe. Can't read it to save myself. If you have progressed or can get them done count me in for 50 or 60 dollars or whatever for a true repro. My plate is not much good to use as a template. Can you help out? Quote
aegean Posted November 19, 2008 Author Posted November 19, 2008 Unfortunately I don;t have any other photos. I had one - not sure what model, but I had a computer crash a while ago and lost it. There are plenty of cars around, so it shouldn't be hard to get one from somewhere. Anyone like to post a photo of their plate ? It would be good to have a library of all years and body styles as I know there are variations. Quote
V8Datto Posted November 22, 2008 Posted November 22, 2008 Here is a picture of the early 240z plate I'm after. Quote
Mr240z Posted November 22, 2008 Posted November 22, 2008 Not sure if this is same thing you guys are after but on ebay aus starting at $19.99 http://cgi.ebay.com.au/Datsun-Nissan-Blank-ID-tag-new-remanufactured_W0QQitemZ220315905214QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item220315905214&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A10%7C39%3A1%7C240%3A1318 Quote
aegean Posted November 22, 2008 Author Posted November 22, 2008 It is fairly similar, but I don't think the original is brushed Aluminium - at least mine's not, and I wonder why, if they are going to reproduce it, that they wouldn't make it the original size ! As they comment, It is identical to the original other than its size as it could be a little smaller. V8Datto - can you measure your old plate and see what the size is ? Quote
mtopxsecret6 Posted November 22, 2008 Posted November 22, 2008 mine is 100 wide and 78 high. theirs is hlf the size.. mine is aluminium. Quote
V8Datto Posted November 23, 2008 Posted November 23, 2008 Right plate below is off an early 240z Size is 100mm wide x 69mm high Quote
V8Datto Posted November 30, 2008 Posted November 30, 2008 So aegean, can you order us a plate? I'm keen, what other info do you need? Quote
aegean Posted November 30, 2008 Author Posted November 30, 2008 Can do. I am just trying to get my head around the size mentioned by mtopxsecret6. He mentions his is 100 x 78, but didn't say what year/model his is. If you're reading the thread, can you let us know ? In the meantime, send me a PM with your chassis details and we can discuss off line. Craig Quote
mtopxsecret6 Posted November 30, 2008 Posted November 30, 2008 woopsy.. mine is actually 100mm wide. and 69mm high. Sorry. It is a 75 260 2+2. not sure how i got 78mm high.. guess i was just excited that i had another piece of my car with me, but i know have the whole car with me!! "the crowd rejoices"! Quote
aegean Posted November 30, 2008 Author Posted November 30, 2008 Thanks for that. Is it the same as the one I posted on Nov 17, or the same as V8Datto's ? You will see on mine that the vertical line dividing the left and right fields only goes as far down as the top 4 lines, whereas the other one extends all the way down. Quote
V8Datto Posted December 1, 2008 Posted December 1, 2008 Craig check your messages, pm sent,..... tho I'm unsure if it made it? Quote
nizm0zed Posted December 1, 2008 Posted December 1, 2008 I would be keen too, had some overspray on mine, rubbed it off anf the black paint came off too :'( Q. does anybody know, would it be illegal to get my new engine no and capacity (and power output) written on it instead of the origional info? i dont see why it wouldnt, its a japanese issue plate, not an aussie one. so shouldnt be required for rego purposes. Quote
mtopxsecret6 Posted December 2, 2008 Posted December 2, 2008 i cant read mine.. so i cant say which style it is. sorry. Quote
aegean Posted December 2, 2008 Author Posted December 2, 2008 It's probably the same as mine, with the vertical line running only part way through the centre. They seem to have changed in the transition form the 240 to the 260. Quote
V8Datto Posted April 22, 2009 Posted April 22, 2009 Thanks Craig, Returned home from OS to find a nice package in the mail, my new replacement plate! 100% match to the original 240z, Thanks again -AB Quote
