Try Les Collins, or Lou Mondello, prob better luck with Lou, he has the dyno next door to his shed.
Worst comes to worst,,, and it has been done plenty times before,,, using jet drills, drill out some smaller ones, or if only have larger ones, silver solder them up, and drill to size.
AND, grind off the stamped size, so that future uses will not take for granted what they WERE!
( they'll just simply have to insert shanks of jet drills to determine the new sizing!)
Found! Mods can remove topic.
Hi Mate
As you started the topic you can also delete it.
Just go the Wanted board, and click RED X on the right hand side
Hi Mate
I have previously used the option to remove my individual posts, but next to this topic on the wanted board there is no red X  :-[
P.S. I type all my posts with an 18" stillson and a mash hammer, technology is my nemesis.
