Pretty sure you don't need to weld them up. My P90 still had the notched ports but ran carbs. I'm 99% certain the intake manifold seals up against it I.e no vacuum leaks.
Bolt 'em straight on.
The little divot for the injectors wont interfere.
Be an idea to pirt match, using the gasket as a pattern, to keep air/fuel mixture flow even, without little steps or ledges to navigate.
