As the topic says, looking for some lowered springs for my 240z - Ideally to lower the car 1-1.5 inches and stiffen the ride somewhat.
Would love to get springs with around 200lbs - 300lbs but happy with as low as 150lbs+ if they are available. Unfortunately the set I had ready to install don't fit the spring seats/perches so am trying to source another set.
Hoping someone has a second hand set lying around they are happy to get rid of - budget up to $120 posted having seen low king springs (and others) sell here for $50 and $100 in the past in decent second hand condition. If you have a brand new set that suits please PM and I'll see if I can stretch the budget.
Can pick up in Adelaide, feel free to PM or call/text 0403 five two seven 398.
James
Nobody?
Will just buy new if no-one has any lying around - King springs are going to set me back $250 so I'll be happy to spend up to around $200 for a second hand set with a linear spring rate (as opposed to the progressive found in the king springs).
kins std height are a linear coil, grab some and lop half a coil off them, this also makes them stiffer again...
have you looked at the top isolator size/height????
if you happen to have the really tall ones, you could swp out for the slimmer 240z front items, which drop 1.5' alone!!!
nat0
nat0
I had heard of that being done, but doesn't cutting the spring damage its integrity? I don't really have the appropriate tools either... I don't suppose you know the spring rates on king std height springs?
Never mind, got the following info from king springs:
KDFL-08   305mm 100-170lb (needs to be progressive to be captive at full drop)
KDFS-08  295mm 185lb
KDRL-09  285mm 175lb
KDRS-09  315mm 175lb
