zomb13 Posted November 9, 2013 Posted November 9, 2013 hi all, is anyone selling a motor? mine is blowing smoke and i want to see whats around. thanks. Quote
pauly_adams Posted November 9, 2013 Posted November 9, 2013 I would be looking at your head, its more then likely leaking valve stem seals Quote
zomb13 Posted November 10, 2013 Author Posted November 10, 2013 i think your right, what would work out cheaper? Quote
pauly_adams Posted November 11, 2013 Posted November 11, 2013 stem seals by far, this is a bit of a patch job ut with limited tools it should help rule out rings, go to supercheap and buy some "liquid molly engine oil re sealer " if the smoke starts to go away or gets less there is a pretty good chance it is your stem seals and for $14 its cheap enough to give it a go anyway, it will not last but might get you out of the poo for 6 - 12 months if your lucky but this is just a band aid and it will still need to be fixed. it takes between 20-200km for it to work. it worked on mine but like I said its a band aid Quote
Administrators gav240z Posted March 27, 2014 Administrators Posted March 27, 2014 I posted a link to 1 on Gumtree in the eBay thread have a look there. Quote
C.A.R. Posted March 27, 2014 Posted March 27, 2014 I've got one here that's stripped down ready to be rebuilt. N42/N42 combo. $650.00 Quote
zomb13 Posted March 29, 2014 Author Posted March 29, 2014 Thank you, want one ready to go but will keep in mind. Quote
