Hi, just seeing where to find an exhaust header flange plate for an L28 so I can have a custom turbo manifold built for my L28, preferrably 12mm thick but no thinner than 10mm, cheers, John
Start emailing the header manufacturers, they have the laser cut patterns on CNC laser or water cutters.
Most use a thinner plate, the 12mm will be a special for them.
If they cant do 12 mm,
Consider what they can supply, and weld on upper and lower gusseted support brackets, where each pipe comes out the plate.
A thicker ex mani plate and a std thickness inlet can be compensated for by welding bits of half washer to the full washers that go under the studs/bolts.
It is a good idea to fit helicoils to the threads that you will ge using bolts for.
Slightly longer studs along bottom is also a good idea.
The thicker the ex mani flange plate the less it will have tendency to bend/warp, and crack due to heat/cool etc.
There is engineering workshop in Launceston and Think Jensons metal works in Burnie do water cutting should be able to make it up for you if you supply a gasket as template Can check it out with my flange supplier they may have template already on system ill let you know tomorrow night
mick
Spoke to my flange supplier today He has not made a l28 one before but if you have a Nissan metal gasket he can cut a flange plate to match Cost would be $80 send me a pvt message if I can help
Thanks
Mick
Mate you are in luck....I have one in the shed from years ago when I used to build manifolds at Mahnkens Autotune in Melbourne. Let me know if your Tassie supplier doesn't work out and I will get it over to you.
Jamo
