44014 Posted September 15, 2013 Posted September 15, 2013 Hi guys , after some advice on cdi boxes . Just purchased a lt12s to run my 20B project and I need to get a cdi box . Should I get a m&w ignition set up or is the microtech x6 adequate ? There is a massive price difference between these 2 cdi's Can any one help me ? Cheers Doug Quote
Ledge Posted September 15, 2013 Posted September 15, 2013 Hi Doug, A good mate of mine owns Jazmac Performance, He is a rotor Guru. He only uses Microtech units. Cheers Paul Quote
NZeder Posted September 15, 2013 Posted September 15, 2013 Most of the rotor guys here in NZ seem to favour Microtech for this task. Quote
Ledge Posted September 16, 2013 Posted September 16, 2013 Hi Doug, Spoke to Steve today about the M&W ignition. He said it is a bloody good thing but you need to way up whether its worth the extra cost over the Microtech unit. Apparently its a bit more work to set it up. Hope this helps Regards Paul Quote
44014 Posted September 16, 2013 Author Posted September 16, 2013 Yer well that's thing the ecu I bought is from the PAC performance 20B rx3 That was set up with a m&w Cdi box ( there changing to haltech because the microtech is struggling to run the 16 1700cc Bosch injectors ....) so I think I'll just save up and get the m&w set up . Cheers Doug . Quote
