Hey guys, after a long break from doing anything to the car, i am now in a financial situation where i can
afford to keep working on it!
I'm now up to the stage where i need a rotiss so i can take the car to get blasted. Where is the best place
i can buy a cheapish second hand rotiss?
That does seem the best way... Do i need any specific dimensions in regards to width or height?
(Width so it doesn't tip over and height so the car can fully turn around)
Robbie, cut the neck/upright in the middle & add an extra 300mm to it, to make it taller so the Zed will rotate a full 360deg.
You may also like to widen the axle tube to the same width as the Zed to aide stability.
Example:
