KatoKid Posted July 24, 2013 Posted July 24, 2013 Hi all. Any suggestions or recommendations for fuel tank repairers in SE suburbs? There are a few in the northern suburbs but want to avoid the long trip if possible. Thanks. David Quote
KatoKid Posted July 24, 2013 Author Posted July 24, 2013 Hi Lurchos. Its got a pretty good dent in the shallow section that sits under the spare wheel well and will (I think) require a piece cut from the top side to provide access and push the dent out of the bottom and then replace the cut out piece on the top. Also need the old fuel sender opening closed over and the old fuel line pick up removed so my preference is for silver soldering rather than welding for these jobs, hence the preference also for a radiator shop that also does tank repairs. Quote
