Greetings all, I am chasing a few bits to help progress the reassembly of my 71 Z.Ah, The problems of buying a project that you carry out in cardboard boxes after 3 previous owners have had a go at. Am I crazy well yes. The bits needed are 1 x LH door window regulator, 1 xRH  Assy Sash Door, this bit guides the glass as it goes up & down. the mud guard fenders that go between teh guards & the body at the rear of the front wheel arches. On the 71 models these bolt on but changed later to being welded on.
Also the alloy lifters for the doors when they close & slide on the nylon slides  I am quite prepared to pay for all these bits as well as postage or depending on where you areor  have them picked up. Any help is greatly appreciated. Cheers Hopo.
I'm tipping they will be hard to get. The door guides wear and sometimes crack, and the inner splash guard you may find on a wreck, good luck, it's always the little things that take the longest  to sort out.
