luvemfast Posted February 14, 2013 Posted February 14, 2013 Didn't know really where to put this..... but I've always been a bit annoyed when I think one way in Engineering measurements. then others speak in other units, may as well be speaking another language! So, I've compiled a few conversions that I think are important and may help others. I hope I've got my figures correct, if not. let me know and I'll edit them. Length 1 inch = 25.4mm Weight 1kg = x 0.45359237lbs Power 1kW = x 0.735499hp Torque 1Nm = x 1.355818ft/lbs Pressure 1kg/cm² = x 14.223343334 psi Speed 1kph = 0.6214mph 1mph = 1.609kph Quote
thriller Posted February 14, 2013 Posted February 14, 2013 All you ever need to know is wolframalpha.com Everything you can think of. HP to KW to PS to you-name-it Quote
dat240z Posted February 15, 2013 Posted February 15, 2013 are you sure about that kg to pound conversion? that would mean a 240z would be 4500lbs plus!!! Quote
Six_Shooter Posted February 15, 2013 Posted February 15, 2013 When I read the title, I expected to see: k = x10^3 m = x10^-3 u = x10^-6 n = x10^-9 Quote
luvemfast Posted February 15, 2013 Author Posted February 15, 2013 When I read the title, I expected to see: k = x10^3 m = x10^-3 u = x10^-6 n = x10^-9 No! Something easy to read Like when someone says he dyno'd an L4 to 289hp 185ft/lb I'm like ohhh, you mean 212kW 250Nm Quote
Six_Shooter Posted February 15, 2013 Posted February 15, 2013 No! Something easy to read Like when someone says he dyno'd an L4 to 289hp 185ft/lb I'm like ohhh, you mean 212kW 250Nm See, now you're just talking gibberish, it's HP and ft/lbs. The engineering notation I posted is easy to read. Quote
BobsYourUncle Posted February 15, 2013 Posted February 15, 2013 are you sure about that kg to pound conversion? that would mean a 240z would be 4500lbs plus!!! Yeah, the kg to lbs conversion is incorrect, it should be 2.2 (1 lbs = 16oz = 0.454kg) https://www.google.com.au/search?q=1+kg+in+lbs Quote
dat240z Posted February 16, 2013 Posted February 16, 2013 (1 lbs = 16oz = 0.454kg) https://www.google.com.au/search?q=1+kg+in+lbs Haha, the old pound to ounce conversion never fails.......... Quote
