zzzzed Posted December 27, 2008 Share Posted December 27, 2008 I have a few questions regarding the l28 n42 block v f54. I have one of each in my collection. First off I will tell you what i have planed, I have a p90 head and turbo manifold so i will be adding boost. I will be aiming for a streetable power figure between 200 and 300rwhp. heres the questions 1. which block would be better suited for my application. 2. will i need forged pistons for these power figures 3. how much power can a stock bottom end handle with boost Thanx Mick.... Quote Link to comment Share on other sites More sharing options...
NZeder Posted December 27, 2008 Share Posted December 27, 2008 For Turbo setup I would got the F54 as this is what Nissan used for the L28ET. However don't go for a large bore ie nothing larger than 88mm ie 2mm over as you want more meat for boosted setups. If however you are going stroker and large bore I would say stick with the N42 as these are better suited for this application IMHO. That is my 2 cents. Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted December 27, 2008 Share Posted December 27, 2008 Basically what Mike said. The N42 block is the one to use for the stroker as it can be overbored more successfully due to the thicker casting & full webbing between the cylinder jackets. The F54 is only simeised between 1&2, 3&4, 5&6. This is better for turbo applications as it provides better cooling of the cylinder bores. Quote Link to comment Share on other sites More sharing options...
zzzzed Posted December 27, 2008 Author Share Posted December 27, 2008 I dont think i will need to boar or stroke for the power figures i am aming for so i will go the f54 and keep the n42 for back up. I found this thred on hybridz of the in's and outs of l28et it almost makes it sound easy. Its worth a read for all the boost nuts http://forums.hybridz.org/showthread.php?t=84860 Quote Link to comment Share on other sites More sharing options...
