scott Posted March 20, 2014 Share Posted March 20, 2014 Hey guys. I got a rb20 gearbox to convert to the L6 but my question is can i use my housing from a 4 speed box or will i need a 5 speed housing? Quote Link to comment Share on other sites More sharing options...
d3c0y Posted March 20, 2014 Share Posted March 20, 2014 What is the 4 speed out of? No zeds in Australia came with a 4 speed. Quote Link to comment Share on other sites More sharing options...
scott Posted March 20, 2014 Author Share Posted March 20, 2014 240k. I got given this box when i bought a load of parts. No idea what it could be from and if its a 4 speed or 5 speed. Has these markings Only after the front housing for my rb20 box Quote Link to comment Share on other sites More sharing options...
d3c0y Posted March 20, 2014 Share Posted March 20, 2014 Have you got a picture of the housings for that box, that is generally the easiest way to tell what it is, for me anyway. Looking at the internals it looks like a five speed to me. Quote Link to comment Share on other sites More sharing options...
scott Posted March 21, 2014 Author Share Posted March 21, 2014 Quote Link to comment Share on other sites More sharing options...
d3c0y Posted March 21, 2014 Share Posted March 21, 2014 Looks like the right bell housing to me. Compare it to mine and others on the internets. Quote Link to comment Share on other sites More sharing options...
Riceburner Posted March 21, 2014 Share Posted March 21, 2014 I'm no expert but it looks the same as my old 260z box only better, Supposedly fully rebuilt but looked like it was found at the bottom of the ocean. Dat2kman or PMC are experts on this. To be certain you could swap the front mainshaft & countershaft bearings from the 260 gearset to the RB gearset, enlarge the shift rod holes and see if it slides together (the anti rattle shim will bind on the L series bell housing inner face, kinda looks like a power saw blade) or leave the shim off. If it does get the bearing holes enlarged and the inner face plunge cut to suit RB sizings. Stuart Wilkins motorsport has all the bearings, syncros, seals in stock. I did an RB20det close ratio rebuild a not too long ago, it's so much better than the original boxes! Quote Link to comment Share on other sites More sharing options...
dat2kman Posted March 21, 2014 Share Posted March 21, 2014 YES It is the same front bell. Follow the instructions on this site re drilling/machining etc. It bolts on and in. Quote Link to comment Share on other sites More sharing options...
nat0_240_chevZ Posted March 22, 2014 Share Posted March 22, 2014 What is the 4 speed out of? No zeds in Australia came with a 4 speed. There Were also the trusty 1600, 180b, 200b and a couple more which came with a factory 4 speed........... Quote Link to comment Share on other sites More sharing options...
dat2kman Posted March 23, 2014 Share Posted March 23, 2014 There Were also the trusty 1600, 180b, 200b and a couple more which came with a factory 4 speed........... watch though, some were a 63A model, the bells are very different Quote Link to comment Share on other sites More sharing options...
d3c0y Posted March 24, 2014 Share Posted March 24, 2014 There Were also the trusty 1600, 180b, 200b and a couple more which came with a factory 4 speed........... Yeah obviously, but what are the chances of someone going to the effort of putting one in a zed? Quote Link to comment Share on other sites More sharing options...
nat0_240_chevZ Posted March 24, 2014 Share Posted March 24, 2014 Yeah obviously, but what are the chances of someone going to the effort of putting one in a zed? Normal people no, not really, but I have pulled 2 4 speeds from them, one an early series the other with customised tailshaft an g/box crossmember, not saying they came out with them, but there are many others about, just point of interest. I myself put a 240k box and l24 from a K into a stationwagon as its the only motor and box I had at the time. Had to swap sumps and mod the oil pickup but not a big deal by any stretch.. Quote Link to comment Share on other sites More sharing options...
scott Posted March 26, 2014 Author Share Posted March 26, 2014 So i ran around trying to find a machine shop that could do it today. First 2 couldn't then the 3rd wanted around $500+ and the following said 2/3 hours at $80/$100 a hour but their machiniest is away on compo atm. $500 sounds way to step and then next one isn't so bad. What have people paid for there work? Quote Link to comment Share on other sites More sharing options...
