reverendzed Posted June 2, 2008 Share Posted June 2, 2008 Hi Guys..need some help as my brake lights won't GO OFF! I don't know if I did something when I reassembled the rear, but they were working fine initially and now they're on all the time. I've checked the switch at the break and that all seems fine....I'm not sure what to do next? If anyone knows Mayhems number could you PM me as I will take it to his shop if I can't fix it. thanks .....Rev. Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted June 2, 2008 Moderators Share Posted June 2, 2008 It could be just your brake light switch. Do they go out when you disconnect the plug from the brake light switch? Check the system; if you disconnect the plug then connect a loop of wire they should operate. Also, if you disconnect the plug and they still remain on, you have a problem! Hope that helps.... Quote Link to comment Share on other sites More sharing options...
Toecutter Posted June 2, 2008 Share Posted June 2, 2008 Take your foot off the brake pedal! Quote Link to comment Share on other sites More sharing options...
reverendzed Posted June 2, 2008 Author Share Posted June 2, 2008 toecutter...you're da man!....if only I had thought of that first! Went down to Mayhems shop today and he fixed it in seconds! Quote Link to comment Share on other sites More sharing options...
lightmaster240z Posted June 2, 2008 Share Posted June 2, 2008 I like the way you think toecutter Quote Link to comment Share on other sites More sharing options...
