vramjee91
Everything posted by vramjee91
  1. Thanks guys. The speed Hut ones look good. I shall be waiting till the end of November!!! Just to make sure, are these the correct sizes? http://www.speedhut.com/customizer.i?clid=1204535 Cheers again
  2. Hey guys, Just wondering what people are using as after market Speedo's and for their other gauges? I am interested in changing all of mine, as a couple dont work and figured it would be good to give it a big of a face lift! Interested to see what people have and where they got it from
  3. Hey mate, Seat belts available? If so how much?
  4. Hey guys, Wondering if anyone knew where to get a three piece rear spoiler from? Please let me know Thanks Vivek
  5. http://saporita.deviantart.com/art/RAUH-Welt-Datsun-240Z-202894547 What are your thoughts on this? I love it!
  6. Hey guys, Cheers for all your help, I figured it out!! It was a fault with the relay and the accessory wire. All sorted now. Thanks again
  7. Happens all the time guys. Not really sure why its doing this .
  8. Hey guys, I was just wondering if there was a difference in the starter motors of 240z's and 280zx's. I currently have a 280zx box with a l26 engine and 240z flywheel and starter motor. There seems to be a clashing noise and I think it's the flywheel and starter motor are clashing. Any help of ideas as to why this is the case? Thanks guys
  9. Yeh,it was the recommended one from the transmission fluid manual. Thanks tho
  10. Hey guys, Which ones of these two would recommend? http://www.thezstore.com/page/TZS/PROD/SCCB08/21-2123 http://www.thezstore.com/page/TZS/PROD/SCCB08/21-2122
  11. Cheers guys for all the info! I defiantly think it is the bearing collar, as it was from an early 240z box The question now is, can I extend the pin on the slave cylinder? if so how? Or where can i get a 280zx collar?? Cheers guys again, and the oil i used was general transmission oil from autobarn
  12. Hey guys, Thanks for the responses. I have bled the clutch a number of times, I can change the gears when the car is off. The pedal feels a lot more resistant now that I have bled the clutch. The clutch fork was greased, and the pin moves, however im not sure if it moves far enough to be able to change the gears. Anymore info you guys need?
  13. Hey guys, After a few parts: 1. Left hand front fender 2. headlight covers 3. front and rear bumpers 4. Headlight covers 5. Right hand indicator cover Let me know if you guys wanna sell any of these. Cheers Vivek
  14. Hey guys, I have put a 280zx gearbox onto an L26, I filled everything up (Clutch, engine, gearbox etc) However when I try to change gears, the gears wont change. I am not sure why this is the case. The only thing I can think of is the fact that I used the clutch bearing holder (mounts onto the fork) from a 240z gearbox. Am I missing anything?? Is this the case?? Help please?
  15. Cheers guys, Appreciate the help. What I do have is a 240mm flywheel and a 225 clutch Time to start looking! Cheers Vivek
  16. Hey guys, Just needed some help with my flywheel and clutch install. I have a flywheel, that I got off a member, and a clutch pressure plate from the US. They don't seem to be lining up. As such I was wondering if anyone had the dimension from one dowl to another of the flywheel? This way I can make sure the flywheel is right and I need a new clutch. The clutch was said to be for a 240z. Help would me much appreciated.
  17. vramjee91
    HELP
    Thanks! Ill be getting these over the weekend !
  18. Hey guys, I have a free L24 (E80) if anyone wants it. Carbs are sold, and its only the complete block. Let me know if anyone wants it. Need to clear some space. Cheers Vivek
  19. vramjee91
    HELP
    hey guys, I am currently in the process of converting my auto into a manual, and have a few questions. 1. Is anyone able to let me know the size of the flywheel bolts? 2. I understand that the transmission bolts are different size to the Auto, is anyone able to tell me the size of the bolts? 3. Is anyone able to also tell me the size of the slave cylinder bolts? Furthermore I was wondering if there are any other bolts that I may need if I was to convert from the gearbox side only?? Help would be appreciated guys Cheers
  20. Hey guys, I was just after some bits for a manual conversion. Need then following: Manual brake pedal bolts plus return spring for a manual pedal spigot bush metal clutch pipping if anyone can help me out here it would be appreciated. cheers guys vivek
  21. I think I have one from my old 260z, I'll try and find it and let you know tonight.
  22. Why you in WA
  23. The engine crane is worth the cash guys, I have one and rate is big time!
  24. Cheers guys! I'll give it a go this weekend and see what happens. Appreciate everyone's help We shall soon find out if it was a wise move or not.....
  25. Hey mate, I think if got some in ate garage, you can have them if I can find them... I'll confirm tonight
