Everything posted by 53-681
  1. Hi how's it goin
  2. The problem has indeed gone... I'm just afraid of a re-occurrence - especially if I'm carrying an extra special female passenger But since it hasn't re-occurred for yourself then I'm pretty satisfied (for both you and me )
  3. That's a fair Australian price. What about engine rebuilds - let's say I want 220HP~
  4. How much is a typical Datsun L6 series box standard rebuild?
  5. Any reputable gearbox shops that you know of down here in Melbourne Jason?
  6. I was driving back home from work last night and as I was waiting at the traffic lights with the clutch in and in first gear, I heard a slight *creak*. I thought that perhaps a bird landed on my roof... The lights turned green and I resumed driving. The vehicle felt odd almost as if it were rolling on it's own even with the clutch in. I changed from first gear to second and it was ok, but the vehicle had this strange feel to it. I was at about 45Kmph when I tried to change into third and **BAM** it would not get into gear! I tried double clutching and even forcing it into gear, but it would not work. I pulled her up onto the nature strip to give it a little rest. It gets into gear when the engine is off, but not when running. I spoke to Mark (Scoota G) and he suggested a few things which may be cause. He then recommended that I stick it into gear while the engine was off and attempt driving home which I did. I put it into second and travelled the remainging 2Km's back home with a max speed of 50Kmph. Upon returning home, before pulling up the driveway I noticed the gear changes were back to normal again! WTF!!!? I then decided to take it for a little race run around the block and she seemed to be behaving normally... I even stuck it into reverse and reversed it up a block 300m. NO PROBLEMS! Has anybody ever experienced a similar problem? If so, what was the cause and what was your approach in rectifying the issue?
  7. Very true, so long as mistakes aren't repeated I think it did come out of the exhaust for a little but then disappeared the following day. So far so good!
  8. I'll be heading to Street Weapon Restorations tomorrow hopefully, but I managed to replace the front right rotor. I can hear a loud humming sound from that wheel when driving above 50KM/H.. I don't know whether it may be the wheel bearing which may be loose or not enough grease on the stub axle... Will find out and post!
  9. Are you still alive?? lol
  10. As soon as I purchase yours yes.
  11. I think I do have some oil on the exhaust... What should I do??? It's not a considerable amount... Should I just smoke it up on the drive to work tomorrow morning??
  12. Hi guys, I was lubing up my linkages and I think I spilt a little.. I was using one of those multi-use small bottle oils (generall used to lube door hinges). I fired her up and took her for a spin. My linkages are no longer sticky wooo! But there is now an awful lot of white smoke rising from the engine bay and exhaust... Did I do something terribly wrong?? Is my Z going to blow up!?!?!??
  13. As Mark said it's all on. Undoing the bolt a quarter of a turn again provided the leeway for the disc to rotate freely. It seems all good, but I think I am hearing mild scrape sounds when steering slightly left.. Going to Street Weapon Restos next weekend for judgement and rectification!
  14. Thanks a lot Scoota. I wish you were in this part of town
  15. OK Sweet. I got the disk in, but now it won't turn freely as it used to.. Is this normal?
  16. Hi all, I have completed half of the phase of replacing the front discs on my 260Z, but have hit a wall. I am trying to fit my new discs in, but cannot for the life of me work out how to put the thrust-washer in after fitting the disc. I have been trying to use a spark plug socket and attempting to hammer it in, but have been doing that for the past couple of hours with no results. Can someone please offer me any advice?
  17. Sorry Gav, but has anybody ever purchased anything from an online Japanese store? I find it quite intimidating to access a website with only native transcript and making a purchase/transaction... I have been receiving a lot of updates on this thread with Japanese auctions and quite frankly I'm not so sure anybody's confident enough to make direct purchases from these sites.
  18. It sounds like a big job with all these blow torches and other tools involved... Is it something I can do within 2 hours on a Saturday with only a wrench and a socket tool???
  19. Reckon you can assist me in getting the handbrake working Scoot?
  20. Thank you dearly for all your responses gentlemen, I really appreciate it. I'll first check to see whether I can purchase gearbox oil with a self pump pipe before I purchase additional tools for the job. I've got a 280Z(X) 5 speed manual gearbox so I could imagine it would be the same procedure as the 280ZX manual.. Is there a specific brand/type of oil you prefer or recommend for L-Series gearboxes? Gareth, you mean like this? http://www.viczcar.com/forum/index.php/topic,10388.msg103572.html#msg103572 Many Thanks
  21. Hello everyone, Could you please point me in the right direction as to how I can go about changing my 260Z's gearbox oil? I have never gone through this procedure before, will be first time. Many Thanks
  22. How difficult is it to rotate the bracket from the 3 o'clock position to 12 o'clock you reckon Scoota?
  23. I don't wish to have any form of engineering checks at this stage... Although i understand where you're coming from. My vision is to drive a retro, stylish, yet affordable sports car. I don't plan to spend thousands as most do on race/competition spec Z's here.
  24. Hey Tai, It hasn't worked since - hence why I had a bit of a 'forgot to take it out of gear' ignition-collision late last year and bumped the front (I wish I retained the nudge bar).. Stock cables are shorter for the R31 calipers so they don't fit in their brackets (I have used springs instead to keep them up so they don't rub against the half shafts). I would like new (recommended for the job) cables to suit the new calipers, but fit in existing brackets. I did drive back from Ballarat so maybe the cables did deteriorate a bit as they were rubbing the shafts on the way back...
