red76z
Everything posted by red76z
  1. The finished Look. P.S If you are replacing the rear hub bearings before you try to press them back into position or bash them in with a hammer and punch, Just put them in your freezer overnight and if they are like mine you can push them into place by hand. It works a treat..
  2. Here are a few pictures of my R31 conversion by modifying the rear struts/hub to suit the complete bracket. I ground the bottom corner and took a bit off each other corner witch allows you to pivot the bracket between 2-5 o'clock . The best angle for the hand brake cable I found is about 3 o'clock. as they say (a picture says a thousand words). I hope this helps in future mods.
  3. That rear end is PHAT
  4. The cv joint is from the Holden Commodore and they seam to take the punishment dished out form the LS1 and they bolt directly to the diff. They are then grafted to the original Z half shaft which are then bolted to the original Z hub. They should do the trick. Time will tell. The weakest link is the original Z axle spline.
  5. The LS1 transplant is well under way with the Diff from the Holden commodore SS V8 Strapped To the original 260z Rear sub frame assembly. The engineer did an outstanding job to put the diff in the same place as the Zed diff and all Bolt in. No need to bolt front of diff to the car tunnel. It has its own frame work. Did not even have to cut wheel well, as he did a mod on the rear cover of the SS Diff to mount to the Z mustash Bar. I have included a few pics Hope You like them. The main reason I went this way was to keep the LS1 with the T56 gearbox 6 speed all talking the same thing with out changing ratios of original diff plus I know that this diff will take the power of the V8 all day long.
  6. Hylux front calipers 300zx ventilated rotors. R31 rear calipers and disc.
  7. I have just finished the front brake conversion with the Hulix calipers and the 300zx front rotors. I had a engineer spin up a couple of spacers to offset the discs from the hub. Awesome job. He did not touch the hub but instead machined the spacers and took a few mm off the center of the 300zx rotors, put a step on them to locate the disc and that is it. They are about 9.8mm thick and made from steel as we thought the step design in alloy would not be strong enough.
  8. I have just left the original struts and springs in the front of mine With the old P76 V8 for years. Now Putting the LS1 into it and keeping the same set up. They work well . P.S the all alloy V8 weighs about the same of a little lighter than the original six.
  9. I have posted some pictures in the gallery. Working on the brakes at the moment. Hilux fromt calipers with 300zx rotors.
  10. red76z
    suspension removal
    From the album: restorations
    Lining up the crane
  11. red76z
    restorations
  12. red76z
    suspension removal
    All bolts are out ready for take off
  13. red76z
    suspension removal
    It is so easy then the car is upside down.
  14. red76z
    suspension removal
    Its out
  15. red76z
    suspension removal
    the front end is out
  16. red76z
    donor parts
    It's Chop time.
  17. red76z
    donor parts
    The old donor car gets the chop from the rip saw. This tool about 3 minutes. I love power TOOLS.
  18. red76z
    donor parts
    Wheel arch from a donor 76 260z.
  19. From the album: restorations
    dummy fit 4b welding on
  20. red76z
    doner parts
    cut the side out of my car and bottom rail. Re fab new rail and welded on.
  21. red76z
    About to start
    Just loaded onto the spit that I made ready for action.
  22. red76z
    THE FIRST CUT
    This was the first panel of my car to see a 4" angle grinder.
  23. red76z
    LHS nose repair
    Cut Plate ready for welding
  24. red76z
    LHS nose repair
    Cut the LHS nose rust out, made new plate and welded back in.
