WTD: Early Hitachi Radio (1970) for 240z
So just putting this out here for now. No rush at all. Since I think I managed to score an early 'arrow' type antenna I'm continuing the theme and looking for the head unit to suit it, looks like this..
I believe the model code is: TM-1081ZA
Looking for 1 in any condition. Working or busted - missing faceplate etc.. it doesn't matter.
Ideally you have something that's been sitting in your garage forever and you'd like to see the back of it ;)
Would be a good project to tinker with and restore and would look the ducks nuts in my 240z ;).
Reference photo below is HS30 00151 (sister car to #150).
2013-12-09
I was hoping to get 1 a bit cheaper than that. I don't mind if it needs restoration. That's half the fun isn't it?
It does look mint though.
Same seller has one without faceplate and knobs for $625. He restores the radios and sells them. His stuff does look immaculate. Maybe if you found a non-working one with the faceplate and knobs and then bought that one it might save you a bit. Big$ for a radio, but guessing early 240 ones are hard to come by. You going the OEM path on the gold one now Gav? Cheers
Gav, I have a a radio but with # TM-1081ZB(S) bare with no knobs or face etc... Let me know if its suitable.
Hi Dimitri,
TM-1081ZB(S) appears to be the same (if maybe a little different internally?) - based on these links it appears to have the antenna switch at the right hand side. Is that what your 1 looks like?
http://www.ebay.ca/itm/Datsun-240Z-AM-Seek-Scan-Radio-70-71-Use-YOUR-Faceplate-Knobs-Save-Big-OEM-/251674148800
http://www.classiczcars.com/forums/electrical-s30/38124-oem-z-radio-questione.html
This is what the later 71-73 radio looks like for comparison.
http://www.ebay.ca/itm/Datsun-240Z-AM-FM-Radio-70-73-Restored-OEM-Stunning-/291264696465
Early ones can be found but seems I'm not the only person who wants 1. I am trying to keep the car as OEM as possible. I will likely install a modern head unit somewhere out of sight like under the glove box etc.. I don't really want to use it for sound, more for keeping the interior looking correct.
  • 1 month later...
Thanks mate, but I got this at the BBQ on Saturday.
http://www.viczcar.com/forum/index.php/topic,13624.msg161255.html#msg161255
I just need to find an antenna switch now (couple on eBay) and faceplate -hoping for a reproduction to be made soon if not it's 3D printer time.
Now looking for a 72 style radio. With the left right antenna switch.
