Hi Guys,
I need an original set of door hinge bolts for an S30z (not sure if they changed over the years, or if the 260z or 2+2s were any different or not? I suspect not..) but my drivers door has other bolts and I'm encountering some resistance trying to tighten them up and don't want to strip the threads on the nuts. So looking to see if anyone has any laying around spare. Just need them for mounting my door in place and trying to align it before spot welding the door skin permanently in place.
Refer to thread here for details.
http://www.viczcar.com/forum/index.php/topic,4189.msg159819.html#msg159819
Any help would be appreciated as I want to get this door tacked in place so I can move on with other panels.
2+2 bolts are different as the doors bolt from the outside, they are longer. 240 bolts are shorter, not sure about 260 coupes.
                Pretty sure I have a set somewhere in my shed. Will check for you today.
                                                  Regards:Alan
Thanks for clarifying, I suspected they might be different.
                                                  Regards:Alan
Thank you!
              Hi Gav, I will check thru my bolt stash & see what I have.
        Regards: Alan.
    G'day Gav , have dug up a dozen bolts to suit your needs mate. Whilst they are not 240Z they are the same length & exact thread as the bolt I took out of my 260Z S30 to compare with. Hopefully they will help you out.
                                                    Regards: Alan
:D
                      G'day Gav, They're free to you mate, down in sydney this week so no prob's to leave them in your letter box .
        Regards: Alan.
Thanks I'll send you a PM with my address.
