moodah Posted March 13, 2013 Posted March 13, 2013 I have an almost complete set up that im considering selling either as a whole or some parts individually. As a whole; - F54 Block. +1mm overbored. Casting flash removed - Forged 87mm JE Pistons (Altered 3mm pin height to match rods) - Forged 240z conrods - ARP Head studs, Main studs & Rod bolts - Performance rod & bearing shells - Stock L28 Crank - Stock NA De-Webbed Intake Manifold - Stock Turbo Exhaust Manifold (appears to be brand new) - N42 Head. w/ porting & deburring (appears to have had a valve job) - Performance cam (Unknown grind. No engine builders have been able to tell me what it is) I have some other bits; - L28 distributor - L28 oil pump (used) - L28 water pump (used) - L28 to Z32 transmission adaptor (appears to be billet and powdercoated, from memory either the engine or bellhousing requires light machining) - Z32 transmission (unknown history, purchased from a bloke cleaning out his shed. its a fairly large monster. No clutch/flywheel. The engine needs a few things to be complete.. Like a new water pump and perhaps high perf oil pump. I was intending to run a z31 ECU and fuel injection system and was figuring it out as I went along. This is a project that I have no use for any more. My current rb30 power-plant has appeared to start leaking from the engines gearbox bellhousing welch plug. I am going to assemble a new rb30det and I need my engine stand back. I have very little time to screw around so please dont waste either of our time. All serious offers will be considered. Quote
moodah Posted March 14, 2013 Author Posted March 14, 2013 2k - Rods, Pistons & engine work ? - Headwork ? - L28ET exhaust manifold? ? - De-Webbed NA Intake maniold ? - L28 to z32 transmission adaptor ? - Z32 transmission Looking for around 3k. You can do the maths and work out if thats a decent deal or not. Its just been put on ebay. Quote
