Going from stock sway bars in my race 240z, What size can you get in front and rear sway bars. As in how big can you get them ,and where can you get them from. Anyone have over size and what sort of affect did it have on the car. Cheers.
When I bought my car it had a standard front bar and a 22mm rear bar in it, I think to counter the understeer from the welded diff.  It worked well until I put the cage in and that made it way too stiff in the rear resulting in massive oversteer on the exit of corners.  I went back to a 16mm Whiteline rear bar and it's really nicely balance now.  I've bought a 25mm Selby front bar to try with the 22mm rear bar to see how that works but I haven't had a chance to try it yet.
Big front ARB, none or a thin (12mm?) rear bar. Been a while, ~24mm front? Sort that bitch out, springs and dampers are just as relevant or more so for a race car, but the above will get you well within the zone.
