Hey guys,
I was just after some bits for a manual conversion.
Need then following:
Manual brake pedal
bolts plus return spring for a manual pedal
spigot bush
metal clutch pipping
if anyone can help me out here it would be appreciated.
cheers guys
vivek
I got a return spring and bolt.
Also spigot bush is on ebay for like $6.
Also your auto brake pedal can be used, just cut down the footpad and buy a replacement rubber footpad also on ebay for a few dollars.
And what is the metal clutch piping you need?
Clutch master cylinder to slave cylinder lines? You can get some made cheap at enzed if you can't find
Incorrect. The shape of the Auto brake pedal is completely the wrong shape & will impinge on the clutch pedal.
