I remember someone did an article on modifying hinges to suit gnose.
Hello from New Zealand. I've been searching all over for this info. As Freddy says above, there was apparently a how-to section on this forum somewhere but I haven't been able to locate it.
If anyone can help or knows where I might find the info, that would be great.
Thanks!
Peter
You can buy them on line from the Sates.
I did mine with nothing special. My panel beater convinced me it would work just to weld a bracket to the existing hinges and it works fine.
This is good news. Would either of you happen to have any pics or tips of what you did?
Thanks in advance
