dat2kman Posted May 29, 2012 Posted May 29, 2012 Set of six flat top Nissan pistons suit stock bore L28 or L26, comes with 130mm rods, bolts, gudgeons. Rings and bearings included, so you can see how minimal wear/use these have had. They are in quite good cond, are ex Keith Honour rally car, which ran a L28 F54/P90 combo at stock bore. They are nothing special, but for someone just wanting to up their compression, the'd be pretty good. $100 the lot, Can deliver to Easter Ck in Sydney at end June, or to Melbourne at early August. Have a set of 1 mm overbore flat tops with gudgeons, suit the 133 rods, ( shorter pin heights), but these may have been accounted for by a forum member up here. Located Brisbane, can post if needed Quote
DatPilot Posted May 29, 2012 Posted May 29, 2012 ARGHHHHHHHHH!!!! Mised out again! NNNNNOooooooooooooooooooooooooooooooooo Quote
luvemfast Posted May 29, 2012 Posted May 29, 2012 ARGHHHHHHHHH!!!! Mised out again! NNNNNOooooooooooooooooooooooooooooooooo See here then http://www.viczcar.com/forum/index.php/topic,11212.0.html Quote
