Pedro Posted January 22, 2012 Posted January 22, 2012 Hello again, i am regreasing the car - have a grease gun in my possession. I have managed to find 2 grease nipples per side in the front of the car (totalling 4 in the front). bottom of a suspension arm and strut. Are there any there i am missing? Anyway the two on the LHS were fine. took in grease , the excess comes out when there is enough in there. The other two are not taking. basically refusing to take in grease with a lot of force being put through the trigger of the gun. there must be a form of blockage - so i took out one nipple cleaned it, tested it, put it back in and i still couldnt get grease to go into the darn thing. Its pretty black in there (10 years at a guess since new grease has been applied) Any ideas? I am yet to look in the rear but am led to belive there are no grease nipples? is this right? half shafts etc? cheers, Peter Quote
DAZDA Posted January 22, 2012 Posted January 22, 2012 Hello again, i am regreasing the car - have a grease gun in my possession. I have managed to find 2 grease nipples per side in the front of the car (totalling 4 in the front). bottom of a suspension arm and strut. Are there any there i am missing? There is one on the steering rack (at least on mine there is…) Anyway the two on the LHS were fine. took in grease , the excess comes out when there is enough in there. The other two are not taking. basically refusing to take in grease with a lot of force being put through the trigger of the gun. there must be a form of blockage - so i took out one nipple cleaned it, tested it, put it back in and i still couldnt get grease to go into the darn thing. Its pretty black in there (10 years at a guess since new grease has been applied) Carefully lift the rubber boot, and then try to soak the old grease in oil or Metho, etc. After which turn the steering back and forth to help try to break up the old grease. Last resort - Compressed Air powered grease gun?? Might blow the rubber boot apart if they have perished though. I am yet to look in the rear but am led to belive there are no grease nipples? is this right? half shafts etc? cheers, Peter The original universal joints in the factory half-shafts are greaseable, just remove the small (M7??) bolt and screw in a long grease nipple. Fill ‘til grease starts coming out the seals, remove the nipple and replace the small bolt. Repeat at both ends of each half-shaft. The uni joints in the tailshaft can also be greaseable. That’s about all I found on my 240Z… Quote
gilltech Posted January 23, 2012 Posted January 23, 2012 Ditto, my 260 has grease nipples on the universal joints to drive & 1/2 shafts, the steering rack, steering control arms & on underside of front suspension struts. Often you'll find that nipples aren't fitted so you'll have to do it yourself. Quote
Pedro Posted January 23, 2012 Author Posted January 23, 2012 very helpful guys. ok to confirm. when you guys say steering rack - do you mean the big rubber boots? or a additional nipple to this? Quote
gilltech Posted January 23, 2012 Posted January 23, 2012 Slide back the concertina dust covers at each end of the steering rack - once they are slid back out of the way you should find removable plugs to enable grease nipples to be screwed in for grease injection for the rack. Pump in grease until it begins to appear between rack & housing, then remove nipples & reinstall plugs, & slide dust covers back into place. AFAIK the 240 & 260 racks are slightly different in housing shape. My own car is a very very early 260 so whether it has the 240 or a 260 style rack I don't know, but the regreasing principle remains the same. Quote
