Ok i have the lift pump soeted for my rb20det. What i need to find find out, Is a bosch 044 to much for the stock rb20det ecu and injectors?
The reason i ask is that i will want to up the power later on and maybe even upgrade to an rb25det so if i can get away with only having to buy the fuel pump once and not have to upgrade it later as i add more engine mods that would be great ;)
Hey Mick,
When i had it it was running the equivalent of a 44, just run a pressure regulator with it if you're worried!! Plus once its on the road you will want to go for a more aggressive tune and injectors so you may as well buy the right pump now!!
Ben
They will have a factory fuel regulator, and just make sure you plumb up a return line!  :P
I was reading that the SR20DET run 43 psi and require anoter psi for every pound of boost. Might be a similar story.
That's what the FPR does - maintain relative fuel pressure, regardless of air pressure (a linear relationship).
A rising-rate FPR doesn't work in a linear way, the fuel pressure rise is disproportional to the air pressure.
