I brought an N42 head with a crow cam marked 832 on it - but can't find any details on the cam specs
Does anyone know anything details about this cam type?
thanks
Sounds like someone has had a custom grind done. If you can get a pic showing the profile i can post up pics of the other two grinds they sell.
Scoota
PS. I need a stroker crank :D
You could try searching a little harder...  Further down the engine page on these forums is this thread;
http://www.viczcar.com/forum/index.php/topic,9761.msg97173.html#msg97173
http://www.crowcams.com.au/media/catalogues/42.1%20Nissan.pdf
The link on that post (second link above) shows a profile for the 4-cylinder L-series 30832 which would probably make yours the equivalent of a 58832 even though they don't specifically list one.  Based on that assumption, it would make the profile a 37/65 - 69/33 (Inlet - Exhaust) with 498 Thou valve lift.
Ouch.... didn't think to look at the 4 cylinder version, but that makes sense now
Cheers for your help Dazda
Scoota - haven't had any stroker cranks for a while now, but probaly need to head up your way before xmas so i'll keep an eye out
cheers
K
