wally57 Posted October 5, 2011 Posted October 5, 2011 I've being wondering if anybody has ever had the standard; fuel level, oil pressure, temp, and volt gauges, repaired or re-calibrated, if so where can I get it done. It looks like I will have to change the speedo and Tacho over to 4" VDO gauges to work with the LS1 and T56 gearbox, but for the sake of making the dash look as standard as possible I would like to at least retain the standard smaller gauges and clock if it is at all possible. Wally Quote
PeterAllen Posted October 6, 2011 Posted October 6, 2011 Wally Because I'm using Jag/Smiths instruments I bought these interface modules. http://www.jaguarspecialties.com/wiring-aids.asp They are apparently specific to Jag/Smiths but reference is made to generic modules by other suppliers. With LSx motors becoming something of the engine of choice in a whole range of conversions you might want to search for a product which will allow you to use the Datsun speedo/tach gauges. Quote
C.A.R. Posted October 6, 2011 Posted October 6, 2011 http://ottoinstruments.com.au/ Highly Reccommended. Quote
jamo240 Posted October 6, 2011 Posted October 6, 2011 Ringwood speedo service here in Melbourne have seen and done just about everything to do with instruments too. They got my clock working again (just a bit of a service and tune is all it took), and they are going to do some tach and speedo conversions for me to talk to the RB25 electronics. Cheers Quote
