BobsYourUncle Posted August 21, 2011 Posted August 21, 2011 These won't fit my new car, so they're up for sale. Near new (I'd say less than 25km's) drilled and slotted front (solid) rotors to suit a 260z (I briefly had them on my 74 2+2 with hilux calipers). From R1 Concepts in the US. I'd like $120 - pick up preferred (from Coomera, Ashmore or Ipswich), but will post at buyers expense. Quote
brianz Posted August 22, 2011 Posted August 22, 2011 Hi I was not planning to upgrade my 76 2+2 calipers at the moment but these sound too good to miss out on. Do you still have the Hilux calipers and would you be interested in selling those as well. Will these just bolt on to my standard setup or is additional work/parts required. I live on the Gold Coast so pick up would not be a problem. I appreciate any advice you can give me on this. Brianz Quote
BobsYourUncle Posted August 22, 2011 Author Posted August 22, 2011 I'm keeping the hilux calipers to use on my 240z, so they're not for sale. It shouldn't be too hard to find a set somewhere - make sure you get the solid rotor version if you want to use the rotors I'm selling (or keep your stock rotors for that matter). All you need to do is trim or remove the dust shield and bend the hard brake lines slightly, otherwise it's a bolt-on upgrade. Quote
chris240 Posted August 27, 2011 Posted August 27, 2011 Brian FYI there is a toyota wrecker 10mins south of Coolangatta just on the Tweed river side, he should have calipers....I think his name was Dennis from memory. Quote
