Zedback Posted June 24, 2011 Posted June 24, 2011 Does anyone know what the thread specifications are for the hydraulic pipe fittings (ie brake & clutch)? Wanting to replace hardlines and the rounded off fittings on the ends but imagine I will need to know thread pitch/count/diameter. Quote
NZeder Posted June 24, 2011 Posted June 24, 2011 M10x1.0 is the stock thread sizing hardlines are standard 3/16 pipe. I replaced all my hard lines with new 3/16 bundy tube and stainless steel 3AN fittings. I then have had new flexi lines make up with 3AN fittings on one end and M10x1.0 on the other to suit the callipers - but then I am not using standard M/C as I am using titlon items. Quote
Zedback Posted June 24, 2011 Author Posted June 24, 2011 Thanks NZeder. Would they be referred to as "Steel M10 x 1.0 Male Flare Nuts"? No reason for me to go otherwise so I'm sticking with standard. What sort of places stock these and rolls of bundy tube: brake shops? hydraulic specialists? Repco? Quote
NZeder Posted June 24, 2011 Posted June 24, 2011 I got mine from a brake shop (but that is here in NZ) and the flare used is a standard inverted flare - not a bubble flare like used on Euro cars with metric flare nuts Quote
