Hi guys,
I was silly enough to kill the rigid line that connects to the clutch master cylinder  :-[. Where could I source a new or another one from? How hard is it to bend your own lines if you buy the rigid lines with fittings already connected? Just thinking about what/how I should be fixing this :P
Thanks.
They are not too hard to make with the correct flare and cutting tool.
I would think if you take it to a good brake place they should be able to make one up for you? Take your old one in as a sample.
Ash
Just measure the length with a piece of string then go to a brake place..at most $5? Probably the quickest and easiest way..
