WTB passenger side windscreen washer jet... Help!!
Hi guys, I'm looking for a passenger side windscreen washer jet. please let me know if you have one spare and willing to part with it or know any repair techniques. The pipe the washer tube pushes onto is broken and the previous owner had just pushed the tube on to what was left hence the leak.
Tried to put my 240 through a blue slip today and failed on leaking (broken) washer jet, slow wipers and exhaust too noisy.    Bummer!
Already had exhaust sorted, car is at the sparkies now getting wipers fixed. Just need a washer jet. Very Excited
Thanks in advance Guys
21723_9cba99b232206a2808ea7018d9f90dbd12a96605.pdf
???Hate to suggest it but the elctrcl unit of your wipers was probably ok. All you would of have to do to fix them was remove wiper blades & cowling undo a cple of bolts extricate/remove wiper unit &  pivot arms. Dismantle the pivoting arm itself use waterproof grease & reassemble the unit. Did this to mine it worked like a charm. I'm still going to fit Honda unit tho. An alternative to this is spray unit with WD40, work unit manually to free it up as much as possible let it dry out them a good going over with Penetrine oil.
PS: Not sure but I may have a Psngr washer jet amongst me stu :Dff. Give me a cple a days to check.Will advise you PM ok.
        Regards: Alan.  :D
;) Hey Mick, went thru my stuff & after some searching found one. Works fine.
        Regards: Alan.  :D
;) Xpress mailed your washer unit today. Best of luck with your RWC next tues.
        Regards: Alan.  :D
I received the washer jet today. Thanks Alan, you are a Saviour!!
Also found a 240 wiper motor in good nick at All Z Parts, expecting to pass the blueslip and finally registered by the weekend.
Thanks again Alan.
;D Good job Mick. Warren & Miriam are good people at AllZ can vouch for them highly in pricing & availability of parts, it's just that bloody Warren is so hard to get hold of some times. Recd bank trnsfr OK thanks. What are you doing abt the noisy Xhst or are you going to tell them thats how Zeds sound normally. HaHa.
        Regards: Alan.  :D
