acf321 Posted January 26, 2011 Posted January 26, 2011 Does anybody know what clips / fasteners were used to hold the kick panels in the 71 240Z? I note there are two types available on ebay, the two piece type with the plastic pin, that is used to hold in the plastic panels, and there is another type of clip that is wider and appears to be only a one piece construction. If your original 240Z has kick panels, can you please help me with what exactly are they? As you can see, i'm putting in all the last little OEM bits to the brown hornet, and I need to know exactly what to get. Many thanks. Adam. Quote
NZeder Posted January 26, 2011 Posted January 26, 2011 Looking at the part catalogue all 240z have the same clip and only 2 of them 67931-08700 and as luck would have it the 260z/280z 2 seater also uses the same clip and the 2+2 well same again. Quote
NZeder Posted January 26, 2011 Posted January 26, 2011 And Adam, you know me and the internet - found a supplier for you in Australia and also looks like the same clip was used on many Datsun's over the years as this one has the same partnumber looks like the correct part but is for a 67 Datsun 1000 (410/411 bluebird) see http://www.abouttimespares.com.au/showpart.asp?id=15952 Quote
