zrevival Posted July 11, 2010 Posted July 11, 2010 Just about to fit an N42 head to my L26 The L26 is already bore notched for the exhaust valves from the late model E88 head that was already on there. Given that the N42 - has 44mm inlet valves (as opposed to the 42mm inlets on the E88) , presumbly there has to be notching on the inlet side of the cylinder as well to accomodate these? Quote
Scoota G Posted July 11, 2010 Posted July 11, 2010 Here's a gallery picture of my L26 block with the notching that has an N42 head on it. http://www.viczcar.com/gallery/displayimage.php?album=lastupby&cat=0&pos=4&uid=762 There are only notches on the exhaust side. This is 40 thou (1mm) overbore. Quote
zrevival Posted July 11, 2010 Author Posted July 11, 2010 yes - my l26 looks like that too - with the notches on the exhaust port side If you didn't have the overbore - would you have needed bore notching for the inlets using the N42? Quote
Scoota G Posted July 11, 2010 Posted July 11, 2010 Even as a standard bore block it never had notching on the inlet side. The rebore was done just over a year ago. Quote
kolonelklink Posted July 12, 2010 Posted July 12, 2010 +1 just make sure you use the dowes... done it before, no issues. -pete Quote
