Hi guys,
            I am after a cheap complete R200 diff. If anyone has one that has eaten the cw+p that would be ideal. I will be changing the ratio so not worried about chipped teeth etc. Can organise freight. Cheers.
The one you sold me?! :o
Yeah, By the way the oil was a bonus....hope it didn't go all over your floor. I mustn't have tipped it up long enough...only a dribble came out.
I have  a complete R200 3.7. Not sure if I should hold onto it or not. What are you after from it? Would it matter if it doesn't have the output shafts etc?
Hi Zedman,
                  I need a complete diff with output shafts as I do not have one. The plan is to change the cw+p (which I can get), so I was not worried if the existing Cw+P were stuffed. In fact, I would probably prefer a stuffed R200 if I can find one, firstly because I did not want to change out a perfectly good ratio and secondly because it would be cheaper. What is the condition of yours like? Cheers.
It was removed from a running car so I assume it should fine but like all of them a bit whiney.. Might be hard to find a stuffed r200 as they are pretty solid.
