OZ001 Posted February 5, 2010 Posted February 5, 2010 can someone clear this up for me? will the stock L24 extractors fit on the L28?? or do i have to get proper extractors? Quote
NZeder Posted February 5, 2010 Posted February 5, 2010 If you are talking about the cast iron exhaust manifold then yes. Checking the parts catalogues I have the L24 and L26 have the same part numbers (only 2 listed for the L24 ie upto July 73) the L26 has 4 listed and the last 2 part numbers match that of the S130 (280zx) L28 manifold part numbers. So by the manner of part number succession I say yes 14004-E3000 -> replace with 14004-Y5200 (L24 and L26) 14004-Y5200 -> replace with 14004-P6800 (L26) (the other partnumber listed for the L26 is an Australian market item only so I assume some emissions requirement made the manifold slightly different) From the S130 catalogue 14004-P6800 used up to Jun 79 the replaced with either 14004-U8715 or 14004-U8716 depends on the market model = emission requirements = different header but both replace the earlier 14004-P6800 So basically yes they will interchange perfectly fine now go and do it Quote
OZ001 Posted February 5, 2010 Author Posted February 5, 2010 If you are talking about the cast iron exhaust manifold then yes. Checking the parts catalogues I have the L24 and L26 have the same part numbers (only 2 listed for the L24 ie upto July 73) the L26 has 4 listed and the last 2 part numbers match that of the S130 (280zx) L28 manifold part numbers. So by the manner of part number succession I say yes 14004-E3000 -> replace with 14004-Y5200 (L24 and L26) 14004-Y5200 -> replace with 14004-P6800 (L26) (the other partnumber listed for the L26 is an Australian market item only so I assume some emissions requirement made the manifold slightly different) From the S130 catalogue 14004-P6800 used up to Jun 79 the replaced with either 14004-U8715 or 14004-U8716 depends on the market model = emission requirements = different header but both replace the earlier 14004-P6800 So basically yes they will interchange perfectly fine now go and do it thats great news, thanks NZeder Quote
