I'm looking at putting a fuel return line back on with the triple carbies. So I need to get a "T" piece banjo fitting.
Where can I get one? have looked at a few places without luck.
ta, Simon
Best guess would be a good carby place? Or you can try Mauceri Motors in Clayton. They (from memory) had a nice pile of Dellorto carbs for wrecking...they may have some banjo fittings left over..
Why the need for a return on the triples?
Had the diaphragm on the fuel pressure regultaor sh1t itself after about 200km. Although it did run an EFI fuel pump when we first fitted them.
So I figure that to avoid it happeneing again, run a return line.
Unless you can offer an alternative.
  • 2 weeks later...
  • 7 months later...
You can check the site of banjocorp. Actually, the site can offer you plenty of choices to choose from and might provide what you need . It just depends how much budget you have.
