Mr240z Posted December 22, 2009 Posted December 22, 2009 240z and 260z...........Note the parts listed as NLA can be sourced though different brands using the same part number.. Location Type Year Description Part No ACTUATION Brake M/Cyl 10/1970 - 08/1971 DISC/DRUM, 6 CYL, ALL MODELS JB1020#(NLA) ACTUATION Kit-B M/Cyl (Min) 10/1970 - 08/1971 DISC/DRUM, 6 CYL, ALL MODELS K7542X#(NLA) FRONT WHEEL Kit-Caliper (Min) 10/1970 - 12/1978 COUPE, DISC/DRUM, ALL MODELS K785S FRONT WHEEL Piston (A) 10/1970 - 12/1978 COUPE, DISC/DRUM, ALL MODELS DB2014 FRONT WHEEL Hose LH 10/1970 - 12/1974 COUPE, DISC/DRUM, 6 CYL, 2.4 LITRE, 2.6 LITRE, 240Z MODEL, 260Z MODEL H1152 FRONT WHEEL Hose RH 10/1970 - 12/1974 COUPE, DISC/DRUM, 6 CYL, 2.4 LITRE, 2.6 LITRE, 240Z MODEL, 260Z MODEL H1152 REAR WHEEL W/Cyl LH 10/1970 - 08/1971 240Z MODEL JB2028#(NLA) REAR WHEEL W/Cyl RH 10/1970 - 08/1971 240Z MODEL JB2027#(NLA) REAR WHEEL Kit-W/Cyl (Min) 10/1970 - 08/1971 240Z MODEL K782S#(NLA) REAR WHEEL Hose LH 10/1970 - 07/1976 ALL MODELS H1153 REAR WHEEL Hose RH 10/1970 - 07/1976 ALL MODELS H1153 ACTUATION Slave Cylinder 10/1970 - 06/1972 240Z MODEL JB4045#(NLA) ACTUATION Kit-S/Cyl 10/1970 - 06/1972 240Z MODEL K927S#(NLA) FRONT WHEEL Disc Rotor Standard 10/1970 - 12/1973 240Z MODEL PBR324#(NLA) ACTUATION Brake M/Cyl 09/1971 - 07/1977 DISC/DRUM, 6 CYL, ALL MODELS, 22.22 mm JB1133 ACTUATION Kit-B M/Cyl (Min) 09/1971 - 07/1977 DISC/DRUM, 6 CYL, ALL MODELS, 22.22 mm K7745X REAR WHEEL Kit-W/Cyl (Min) 09/1971 - 06/1972 240Z MODEL, 260Z MODEL K782S#(NLA) ACTUATION Clutch M/Cyl 09/1971 - 05/1975 ALL MODELS, 15.87 mm JB1199 ACTUATION Kit-C M/Cyl (Min) 09/1971 - 05/1975 ALL MODELS, 15.87 mm K7762X REAR WHEEL W/Cyl LH 07/1972 - 07/1976 240Z MODEL, 260Z MODEL JB2313#(NLA) REAR WHEEL W/Cyl RH 07/1972 - 07/1976 240Z MODEL, 260Z MODEL JB2312#(NLA) REAR WHEEL Kit-W/Cyl (Min) 07/1972 - 07/1976 240Z MODEL, 260Z MODEL K1942S#(NLA) ACTUATION Slave Cylinder 07/1972 - 12/1978 ALL MODELS, 19.05 mm JB4055 ACTUATION Kit-S/Cyl 07/1972 - 12/1978 ALL MODELS, 19.05 mm K791S ACTUATION Kit-S/Cyl (Alt) 07/1972 - 12/1978 ALL MODELS, 19.05 mm K1008S REAR WHEEL W/Cyl LH 08/1976 - 12/1978 260Z MODEL JB2675#(NLA) REAR WHEEL W/Cyl RH 08/1976 - 12/1978 260Z MODEL JB2675#(NLA) REAR WHEEL Kit-W/Cyl (Min) 08/1976 - 12/1978 260Z MODEL K1977S#(NLA) ACTUATION Brake M/Cyl 08/1977 - 12/1978 DISC/DRUM, 6 CYL, 2.6 LITRE, 260Z MODEL, 22.22 mm JB1195 ACTUATION Kit-B M/Cyl (Min) 08/1977 - 12/1978 DISC/DRUM, 6 CYL, 2.6 LITRE, 260Z MODEL, 22.22 mm K7655X - - - COUPE,260Z MODEL, Gtv240z 1 Quote
Mr240z Posted December 22, 2009 Author Posted December 22, 2009 280zx all models covered.. ACTUATION Brake M/Cyl 03/1979 - 08/1981 COUPE, DISC/DISC, 6 CYL, 2.8 LITRE JB1361#(NLA) ACTUATION Kit-B M/Cyl (Min) 03/1979 - 08/1981 COUPE, DISC/DISC, 6 CYL, 2.8 LITRE, 23.81 mm K7864X FRONT WHEEL Kit-Caliper (Min) 03/1979 - 05/1984 COUPE, DISC/DISC, 6 CYL, 2.8 LITRE K1178S FRONT WHEEL Piston (A) 03/1979 - 05/1984 COUPE, DISC/DISC, 6 CYL, 2.8 LITRE JB8459#(NLA) FRONT WHEEL Hose LH 03/1979 - 05/1984 - H1179 FRONT WHEEL Hose RH 03/1979 - 05/1984 - H1179 REAR WHEEL Kit-Caliper (Min) 03/1979 - 08/1981 COUPE K1163S#(NLA) REAR WHEEL Hose LH 03/1979 - 05/1984 - H1620 REAR WHEEL Hose RH 03/1979 - 05/1984 - H1620 ACTUATION Clutch M/Cyl 03/1979 - 05/1984 2.8 LITRE JB1363#(NLA) ACTUATION Kit-C M/Cyl (Min) 03/1979 - 05/1984 2.8 LITRE, 15.87 mm K7689X ACTUATION Slave Cylinder 03/1979 - 05/1984 2.8 LITRE, 19.05 mm JB4055 ACTUATION Kit-S/Cyl 03/1979 - 05/1984 2.8 LITRE, 19.05 mm K1008S ACTUATION Kit-S/Cyl (Alt) 03/1979 - 05/1984 2.8 LITRE, 19.05 mm K915S REAR WHEEL Disc Rotor Standard 03/1979 - 08/1981 COUPE PBR601 FRONT WHEEL Disc Rotor Standard 03/1979 - 05/1984 COUPE, DISC/DISC PBR323 ACTUATION Brake M/Cyl 09/1981 - 05/1984 COUPE, DISC/DISC, 6 CYL, 2.8 LITRE JB1362#(NLA) ACTUATION Kit-B M/Cyl (Maj) 09/1981 - 05/1984 COUPE, DISC/DISC, 6 CYL, 2.8 LITRE K8268#(NLA) REAR WHEEL Kit-Caliper (Min) 09/1981 - 05/1984 COUPE K1371S REAR WHEEL Piston (A) 09/1981 - 05/1984 COUPE JB8550#(NLA) REAR WHEEL Disc Rotor Standard 09/1981 - 05/1984 COUPE PBR600 Quote
FLEXZED Posted December 22, 2009 Posted December 22, 2009 awesome post mate Thank you pauly i think you should change your nic to "mr20zsparepartsguru" Quote
(Locky) Posted December 26, 2009 Posted December 26, 2009 REAR WHEEL W/Cyl LH 10/1970 - 08/1971 240Z MODEL JB2028#(NLA) REAR WHEEL W/Cyl RH 10/1970 - 08/1971 240Z MODEL JB2027#(NLA) im in need of these and ATAP can only get the PBR stuff (where most auto joints get there brake stuff from) any ideas where to sorce ?? Quote
Thomo260 Posted January 25, 2010 Posted January 25, 2010 For later 260Z's 7/8" rear wheel cylinder cups to rekit your own, part is #P4477 Quote
