stevo_gj Posted December 21, 2009 Posted December 21, 2009 Hey guys, I'm trying to order some tyres for my 260z but I don't have the car atm and they want to know the stock size and minimum load capacity of the original wheels. I need someone with a 260z to check their tyre placard, its either on the glove box lid or its on the inside of the door. I will donate $5 to the site if I get an answer that details the Stock Size AND the Minimum Load Capacity within the next hour! Steve Quote
Mr240z Posted December 21, 2009 Posted December 21, 2009 From the Haynes book. 260z Wheels pressed steel 5J - 14 Tyres(radial) 195/70 VR 14 Pressures (under 100mph - 160kph) Front 28 lb in (2.0kg cm) Rear--Same Don't know if that helps Quote
stevo_gj Posted December 21, 2009 Author Posted December 21, 2009 Hmm this website here http://www.green260z.com/specs.cfm has 260 specs and it says tyres are : Toyo 2-1 175 HR 14. 195 or 175? Quote
Mr240z Posted December 21, 2009 Posted December 21, 2009 Thats 240z Toyo 2-1 175 HR 14. 260z is under that in the book Quote
Scoota G Posted December 21, 2009 Posted December 21, 2009 This is straight off my 75 260Z Tyre placard 5jX14 with two tyre sizes 175 hr 14 Maximum load 1230 lbs 195 10vr14 Maximum load 1280 lbs Quote
stevo_gj Posted December 21, 2009 Author Posted December 21, 2009 Awesome, I'm going to donate that $5. Cheers guys. Quote
PZG302 Posted December 21, 2009 Posted December 21, 2009 Steve, what size rims are you running at the moment? These will determine what size you need now. If you're running 7" rims you would be looking at about a 205-225/ 55-65/ 14 tyre depending on final aspect ratio you want to run and whether you are too much worried about gearing and speedo. Quote
stevo_gj Posted December 21, 2009 Author Posted December 21, 2009 My speedo has been out since I changed the gearbox hehe, not too worried about it. I believe I'm currently running 14x6 rims but I have no idea on tyre size, perhaps 195 at a guess? Quote
Lynton Posted December 21, 2009 Posted December 21, 2009 195/70 VR 14 Low Profile (Alloy Wheels 5.5J 14) Lynton Quote
PZG302 Posted December 21, 2009 Posted December 21, 2009 Steve, I would suggest a 195 or 205 tyre in either 65 or 70 profile for your wheels, this would cover either a 6 or 7 inch rim. Personally I would go for the 205 in a 65 series, but final choice would depend on tyre availability and budget. Quote
stevo_gj Posted December 22, 2009 Author Posted December 22, 2009 Robbie seemed very keen to try 215s since he has them in stock. I said that I had been recommended 205s but he seemed very set on starting with 215s since he wouldn't have to order any in. :-\ My 17x7.5 rota RBs should be arriving today Quote
PZG302 Posted December 22, 2009 Posted December 22, 2009 A 215 will work as well, I have run upto a 235 on a 7" rim, and have seen 265 squeezed on a 7 as well. As for not ordering any in, more to keep you happy as you get the tyres straight away. As Robbie is an independent dealer it can take some time to get some tyres in, I have had to wait up to a coupleof weeks for tyres for the work ute due to being an odd size and load rating. Quote
stevo_gj Posted December 22, 2009 Author Posted December 22, 2009 Ah that makes sense, thanks Matt. Well keep an eye on my project thread and you'll surely see some pics of my new wheels in the near future Quote
PZG302 Posted December 22, 2009 Posted December 22, 2009 Ahhh, the penny's dropped, you were after tyres for the 17's..... 215's will work very well on a 17.5" wide rim. What profile are you looking at and what tyres has Robbie recommended? When I had my old AU Ute he put a set of Hankooks on it, 235/45/17 and they went very well and were cheap to boot. Basically what Robbie used on his personal ute, so if they are good enough for the owner of the shop they're good enough for me.... Quote
garvice Posted December 22, 2009 Posted December 22, 2009 So what tires are you getting? (Type not size, well size as well) Quote
stevo_gj Posted December 22, 2009 Author Posted December 22, 2009 Actually when I spoke to Robbie I didn't ask him what type of tyre he recommended, he had me checking on the size so I forgot to ask. I'll give him a call tomorrow and find out. Quote
PZG302 Posted December 22, 2009 Posted December 22, 2009 Knowing Robbie, he will be looking at the best bang for your buck tyre, so all will be good. Quote
