Hi guys .......
looking everywhere for these
M8 x 1.25 x 18 pressure plate bolts
coventry fastners dont have them and nissan dont sell them
so where do i go??????????????????????????
Same size was used on
1986 - 1995 Ford Windsor 302
and
Honda SOHC D series motors
and
Honda DOHC B series motors
Try a Honda dealer
Hear is the PDF I got the info from
Opppppppppppppps
Wrong PDF
12393_c80d73a35beab5d2a8385468375377b6e45c8d94.pdf
12394_94516a09ef81317da94baa047e85b24b13b2724a.pdf
You should be able to use some M8 socket head screws..they are a 12.9 grade which is more than enough strength. I have plenty of those bolts here and at my work if you get stuck...I can probably post them to ya! Mine are 20mm in length.
Just ring up a Honda dealer and ask what theirs are, but I'd say that they would most probably be the same length.
  • 2 years later...
Bringing back an OLD thread here but I'm chasing some pressure plate bolts as well, so is it right that the 18 length is just the length of the thread not the whole bolt?
Must be; when you measure any bolt, its always from underneath the head to the end. I've used M8 by 20 with no probz. Even allen key bolts (cap screws) will work fine.
