pauly_adams Posted June 23, 2006 Posted June 23, 2006 hey just wondering if any 1 can give me some info i have this tank or bottle in my zd but its not hooked up its on the drivers side on the side of the car in the engine bay any 1 got any idea what it is ill get a pic soon thanks pauly Quote
zr240 Posted June 24, 2006 Posted June 24, 2006 Yer if its the white one thats close to the firwall on the drivers side its windscreen washer bottle Ash Quote
luke_mcmahon85 Posted June 25, 2006 Posted June 25, 2006 it should have plastic tubing going to under the cowl panel that leads to the sprayers, if it's not hooked up, your sprayers not working...get some aquarium tubing and hook it up Quote
pauly_adams Posted June 25, 2006 Author Posted June 25, 2006 thanks for all the info but for some reason it has no jets and the bottle is half melted at 1 stage i think my zd had a engine fire thanks for everything pauly Quote
Huw Posted June 25, 2006 Posted June 25, 2006 nissan sells the washer bottle & motor for around $100.. just boughtr one for my dad's zed. cause finding an old one with working motor is a challenge. Huw Quote
Rod F Posted June 26, 2006 Posted June 26, 2006 $100! Getting another washer bottle I can understand would be difficult, but if you find a used one with a stuffed motor I bought a generic motor from Supercheap Auto that went straight in, just needed to mod the wiring to suit. Costed about $20. Quote
Huw Posted June 26, 2006 Posted June 26, 2006 depends on what you're after....my father is obsessed with originality in his zed (it's not even an early one though) I just scavenged a couple of bottles (much like what Rod did, except I swapped for an original motor from a shot bottle, but it was hard to come by.) Huw Quote
pauly_adams Posted June 26, 2006 Author Posted June 26, 2006 the stange thing is the motor sounds fine but the jets have been remove Quote
Mr Camouflage Posted July 8, 2006 Posted July 8, 2006 Are you sure the jets are missing? The jets might still be there under the cowling panel. Take a photo of the firewall a i'll see if i can point them out. Quote
