After some clarification. I have a "C" stamped camshaft, which is supposedly a Nismo cam which makes sense as the motor came from Nismo as a crate motor. Apparently the lift is 434/256 duration but it's mentioned as being a high performance cam. Listening to it you wouldn't think hp. People speak of 274 duration cams, is this going to be more of a performance cam than I have presently.Ricky
Is the letter c the only markings on the cam? if so its a standard 260z cam , could also be a reground cam but there should be other markings ussually on the cam gear boss
getting into the cam discussion i have both a camshaft with a A stamped on the back also the one from my 260 has B4 stamped on it i was told the B grind was the better of the cams does anyone know the difference between the factory grinds.
cheers Pauly
The cams with the "A" stamped I'm sure are the early 240Z camshafts that are pre-pollution so a bit "lumpier" than a 260 cam that was profiled for emissions.
only proper way to do it is to do a dummy engine assy, with No1 piston in on the crank only, snig head to block set up cam chain and dial it up, using dial indicator and a degree wheel on the crank nose, better to take readings on either side of tdc, more accurate.
You will then be able to graph out a curve this will give duration/overlap/lift, while at it, then try a different camsprocket hole, and see what this will do for your cam to crank timing ( retard only with the stock three holes)
I'm sure it will have been well covered here somewhere.
