253260z Posted September 30, 2009 Posted September 30, 2009 i have a couple or 260z 2+2 that i am wreakin as they are race cars and dont need much off of them will shipp parts at buyers expence parts gauges speedo,tacho.temp,clock etc windows 2 drivers door 2 passanger door 2 rear dirvers 2 rear passanger one front air con vents battery and master flaps x 4 2 blue 2 green ok condition door handles inner outter window regulators 2 piece sunroof 4 260z front badges one bonnet badge Quote
. Posted September 30, 2009 Posted September 30, 2009 do you have: bonnet vents handbrake cable 260z badge from the boot fairlady badge If so how much do you want for them? Quote
mtopxsecret6 Posted September 30, 2009 Posted September 30, 2009 i'm looking for the front sway bar mounting bolt. Ie the one that holds the sway bar to the swing arm with the bushes on it, a front air dam, Also a windscreen. thanks. Quote
253260z Posted September 30, 2009 Author Posted September 30, 2009 do you have: bonnet vents handbrake cable 260z badge from the boot fairlady badge If so how much do you want for them? by bonnet vents do you mean the pop up ones? using hand brake cable and only badges are datsun and 2+2 Quote
Kent Posted September 30, 2009 Posted September 30, 2009 do you know if the rear hatch hinges (incl mounts etc.) and struts are the same as a 240Z, if so, and they are in good nick, let me know how much you want for them Kent Quote
253260z Posted September 30, 2009 Author Posted September 30, 2009 i'm looking for the front sway bar mounting bolt. Ie the one that holds the sway bar to the swing arm with the bushes on it, a front air dam, Also a windscreen. thanks. what do you mean by air dam the two black things in the engine bay? have all windows but am in adelaide and shipping could be expencive have sway bar bolt Quote
253260z Posted September 30, 2009 Author Posted September 30, 2009 do you know if the rear hatch hinges (incl mounts etc.) and struts are the same as a 240Z, if so, and they are in good nick, let me know how much you want for them Kent not sure if they are the same but are in good nick $50 + postage Quote
Kent Posted September 30, 2009 Posted September 30, 2009 could i get some pics so i can compare? thanks mate Quote
253260z Posted September 30, 2009 Author Posted September 30, 2009 could i get some pics so i can compare? thanks mate ill post them up tommorow Quote
mtopxsecret6 Posted September 30, 2009 Posted September 30, 2009 On the front of the car under the grill. The front air dam, not inside the engine bay. http://i193.photobucket.com/albums/z15/onebadass280z/zcar014-1.jpg under the indicators and head lights on the car in the link. I can organise transport for the bits i want. Have you got pictures of the bits i want please. Quote
zzzzed Posted September 30, 2009 Posted September 30, 2009 On the front of the car under the grill. The front air dam, not inside the engine bay. http://i193.photobucket.com/albums/z15/onebadass280z/zcar014-1.jpg under the indicators and head lights on the car in the link. I can organise transport for the bits i want. Have you got pictures of the bits i want please. you mean the front spoiler Quote
mtopxsecret6 Posted September 30, 2009 Posted September 30, 2009 yeah you know.. same thing.. obviously called slightly different down south, just looking for one. Quote
. Posted September 30, 2009 Posted September 30, 2009 do you know if the rear hatch hinges (incl mounts etc.) and struts are the same as a 240Z, if so, and they are in good nick, let me know how much you want for them Kent I am using 260z hinges on my 240z. You do need to grind them down a bit and modify the bolt holes a little but they do work Quote
Brabham Posted October 1, 2009 Posted October 1, 2009 Hi, I am after the corner pieces of the stainless window trims from the front and rear. Do you have these? Thanks. Quote
253260z Posted October 1, 2009 Author Posted October 1, 2009 Hi, I am after the corner pieces of the stainless window trims from the front and rear. Do you have these? Thanks. might have a couple ill have a look Quote
mtopxsecret6 Posted October 1, 2009 Posted October 1, 2009 use photo bucket or the like and link the photos in Quote
. Posted October 1, 2009 Posted October 1, 2009 The vents I am after are the ones that came on the later model 260z. They are plastic and sit on the bonnet towards the windscreen. Quote
FLEXZED Posted October 1, 2009 Posted October 1, 2009 The vents I am after are the ones that came on the later model 260z. They are plastic and sit on the bonnet towards the windscreen. i have a spare set but the bolts are broken pm me Quote
mtopxsecret6 Posted October 1, 2009 Posted October 1, 2009 so have you got the things ive asked for? Quote
Mr240z Posted October 1, 2009 Posted October 1, 2009 wont let me post pictures Try this.... http://tinypic.com/ Quote
