Kent Posted September 28, 2009 Posted September 28, 2009 Hi Guys, I have a Castlemain Rod Shop gearbox mount to suit an RB30DE, RB30DET or RB25DE gearbox. it is the type of mount that utilises the standard Z gearbox mount. I bought it with a set of engine mounts, but i need the newer style mount for the RB25DET gearbox looking for $85 for it, can easily post anyware (it is quite small in comparison to the rb25det one). located in sydney, and pickup is available Kent Quote
NZeder Posted September 28, 2009 Posted September 28, 2009 So is this for a 260z ear mount or the 240z flat mount? Got a pic? Quote
Kent Posted September 28, 2009 Author Posted September 28, 2009 not sure, can you tell from the attached pic? the guy i bought it off said it was a 240z.. but not sure if it was series 1 or 2 etc. Quote
Moderators Zedman240® Posted September 28, 2009 Moderators Posted September 28, 2009 It is for a series 1 or early bolt up into chassis 240Z. You will need to remove the ends. I have the later style 240/260 bolt through bits if they are needed. Quote
