hey guys, anyone have any of these parts
5 speed manual gearbox (any condition)
pedal box
flywheel.
clutch fork
original clutch line
sandwitch plate
as you can work out im doing a manual conversion on my 74 2+2 260z
all the other stuff like master,slave and clutch will be brand new and the box will be getting reconditioned
thanks guys
Dave, with the sandwich plate, you might be better off using the auto one with the removable lower section. I've had to several times have a peek behind the flywheel and with the one piece plate, that would be impossible. Just thought that would be one less thing you have to chase up. If you prefer the one piece, I have one here I'm not using..
I could help you out with an L28 manual box (I assume they fit), a pedal box, flywheel, even a manual center console. Problem is I'm live in Nth QLD.
Can anyone tell us if the L28 manual box and L26 are the same???
They certainly looked the same when I had an L24 box sitting next to an L28.
Presume you mean gearbox here, and yes a 280zx gearbox will fit into a 260, but the front edge of the gear lever hole in the floor needs trimming by about 15mm from memory.
Or like what I did and just "massage" a gear shifter in the shape of an S to clear the shifter hole. Works but damn it looks ugly!
Gearbox's are the same physically but ratio's are different and oil filler plug is on the opposite side. There are many zeds running around with 280 boxes installed.
  • 2 weeks later...
