hans Posted June 17, 2024 Posted June 17, 2024 Hy Needing 2 differential studs for the cover r200 I believe i need m14 x 1.5 I bought protunerz diff cover It didnt come with the studs I tried to remove the ones on the old cover...sadly no luck Hans Thk u in advance Quote
gilltech Posted June 20, 2024 Posted June 20, 2024 Speaking from past experience, just get new bolts of correct size & enough thread length & cut the heads off, & tidy up the cut thread ends as required; note: make sure they are High Tensile steel as normal mild steel won't be adequate for the application. My 2c worth anyway. Quote
