Huw Posted January 29, 2024 Posted January 29, 2024 Hi all, So, 20 years ago I put a used (repaired) heater core into my 1971 240Z as part of the restoration. Works done by a store in Mordialloc, did a great job on the core and an uprated radiator. However, after driving this weekend, I noticed that there was some coolant leaking inside. I assumed non-standard heater tap had gone again. However, when I had a closer look tunnel was damp and seemed to be a larger leak from the core itself (explain the drop in coolant). Anyway, I don't have time/energy to do the heater core work (2xkids and own business), wonder if anyone has a shop suggestion around SE suburbs? (we are in Hawthorn but I have a shop in Moorabin in mind). Will be: - fault diagnosis (although I have a strong suspicion); - fix; and - hopefully, new cooling system cables all round (had been meaning to buy from US but a shop should be able to make easily) - heater system has always been NQR (I built it...which explain a lot). Have to do it before I can move on to the fun stuff of getting the interior really right... Huw gav240z 1 Quote
