Scando Posted April 14, 2009 Posted April 14, 2009 Due to an upgrade I'm selling my old front brake package. I'll start by warning that this is not a bolt on package and will require some fabrication. What you get: -Mazda Series 4/5 4 spot calipers -Honda Legend Rotors (done one race meeting plus Targa Wrest Point) -Barely warn Project Mu Race pads (RRP around $600) -A bracket that bolts to both the calipers and the original mounting points on the strut tower. What you will need to do. -To get the spacing right the rotors need a 6mm spacer between the hub and the rotor. It's just like a wheel spacer and any good machine shop should be able to make them up pretty cheap. -You will need to weld extra metal onto the mounting point on the strut to mount the caliper to because the mounting holes are much further apart than those on the original Z struts. The bracket provided is only about 3mm thick and nowhere near strong enough to hold the caliper by itself but it if you bolt it to the strut it will give you a very good idea of where the peices of metal need to be welded onto the strut. The bracket will also give the welds extra support once it is all bolted together. I'm looking for $900 for the lot or $550 without the pads. Freight at buyers expense. This package using the pads provided would be perfect for anybody who uses their car for club days or more serious circuit racing. Quote
Scando Posted May 30, 2009 Author Posted May 30, 2009 I want these gone $700 with the pads or $400 without. The pads are the same type and compound as what the V8 Supercars use. Quote
Scando Posted December 2, 2009 Author Posted December 2, 2009 Price Drop $500 with the pads or $300 without. Quote
Zeddophile Posted December 2, 2009 Posted December 2, 2009 That is a bloody cheap deal for someone..... I paid a fair bit more than that just for my front calipers with no pads or discs or anything..... Quote
luvemfast Posted December 2, 2009 Posted December 2, 2009 C'mon people. Why aren't you jumping on this one? Looks like you'll be putting that on ebay, probably get more for it anyway. Quote
WogsRus Posted December 3, 2009 Posted December 3, 2009 if i didn't just buy the DR from you i would buy this instead. Quote
Scando Posted December 3, 2009 Author Posted December 3, 2009 haha, no offers yet so I might still have them when you have the cash Any luck getting the R30 going? Quote
RB30X Posted April 15, 2011 Posted April 15, 2011 im too slow again how did i miss this Well you had over a year to think about it??? The original post was in April 2010. Quote
luvemfast Posted April 15, 2011 Posted April 15, 2011 im too slow again how did i miss this D u d e Y o u A r e S o S L O W Quote
