Yes as soon as you spied the Dellorto topic you should have known it was me.  :P
Does anyone know who can make these idle circuit restriction thingys made? Like the one's in the picture below.
Mike in Sydeny makes them but all you need is a bit of thin brass wire and use a bremel with a 0.9 or 1mm drill bit to make the hole. I think anything from 0.9 to 1.2 mm should be ok.
SUlio
If you are having trouble with the brass rod ( mitre 10 has 0.8mm + drill bits but not the rod. ) you can get some from a hobby store. ( guess who lost 4 of his restrictors! ). Hobbyone had the rod i needed.
